10x voltage rectifier circuit
Source: InternetPublisher:闪电杰克 Keywords: Voltage doubling rectification Updated: 2020/07/06
Voltage doubler rectifier circuit, this circuit achieves an effect N times higher than the input voltage by charging in parallel and discharging in series. Suitable for occasions requiring high voltage and low current. This picture is a circuit diagram of 10 times the voltage. If AC220v voltage is input at the left end, the no-load voltage at the right end is about 3000V.
- How does sand become chips?
- FPGA Features and Architecture
- What are the types of commonly used batteries?
- RC filter explained in detail
- Causes of PCB deformation How to prevent circuit board bending and warping
- Ceramic filter structure/working principle/characteristics/application
- What is the difference between JFET and MOSFET
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- LED lights that “drain” battery power
- Circuit diagram of a voltage doubler rectifier electronic ballast
- Triple voltage rectifier circuit
- Double voltage rectifier circuit
- Odd voltage doubler rectifier circuit b
- voltage doubler rectifier circuit
- Stabilized multi-voltage rectifier circuit with adjustable output voltage
- Voltage doubler rectifier circuit diagram
