FS810 integrated power amplifier circuit diagram
Source: InternetPublisher:宋元浩 Keywords: Power amplifier circuit amplifier circuit diagram Updated: 2021/01/12
The figure shows the practical circuit of the FS810 integrated power amplifier. FS810 is an integrated , suitable for high-end radio recorders and audio equipment.
In Figure (a), the speaker is connected between the output capacitor C5 and ground, and a 100kΩ resistor is connected between pin ⑧ and ground to form an AC feedback branch. In order to make the bass rich, additional C (0.047μF) and R4 (8.2kΩ) branches are added, connected between pin ⑥ and pin 12, as a bass boost network. C10 and R5 are bootstrap networks, and R3 and R4 are reactance correction networks, used to eliminate the inductive reactance component of the speaker.
In Figure (b), the speaker is connected between the positive electrode of the output capacitor C5 and the positive electrode of the power supply. The output capacitor C5 and the speaker impedance also serve as bootstrap network components, so there are fewer components and the circuit is simple, but the speaker must be suspended and not grounded.
- How to adjust the bass and treble of CXA1005
- 6P3P parallel 20W power amplifier experiment
- TDA2009A power amplifier circuit
- Preamplifier circuit made of composite screen triode electron tube 6C5P
- Biliary duct 2A3C Class A amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Audio power amplifier circuit composed of LM4835/4838
- Single power supply audio power amplifier circuit composed of LM3875
- LM4820-6 audio power amplifier circuit
- Integrated circuit audio power amplifier circuit
- Using TA8216H chip audio power amplifier circuit
- OTL power amplifier circuit in transistor radio b
- A757 power amplifier circuit
- New dual loop power amplifier
- Receiver amplifier circuit diagram
- LA4700 audio IC amplifier circuit diagram
- FS810 integrated power amplifier circuit diagram
- 22W power amplifier circuit
