High pressure natural gas stop valve drive circuit diagram
Source: InternetPublisher:国民男神经 Keywords: Natural gas drive circuit diagram high pressure solenoid valve Updated: 2020/04/02
The picture shows the drive circuit of the high-pressure natural gas shut-off valve. Device 01 is a solid-state relay. When the engine is working in a dual-fuel state, the fuel conversion mechanism works, and the logic judgment part issues instructions to make Y4 = 1, which is high level. After U2 (7404, inverter), the electric heating UB at point B is low level. , the potential UA at point A on the surface is higher than that at point B. At this time, the input end of the solid-state relay is turned on and the output end is also turned on. Once the output terminal CD is connected, the rated operating voltage of 12V will be applied to both ends of the solenoid valve HPVALVE, causing the high-pressure natural gas valve in front of the pressure reducer to open, and the natural gas will enter the engine through decompression. When the instruction issued by the logic judgment part causes the solenoid valve to close, Y4=0, after passing through the inverter, B is high level, UA=UB, there is no current passing through the input end of the solid-state relay, and the output end is not conducting, so the solenoid valve It returns to the normally closed state under the action of spring force.
- Hot wire spark plug control circuit
- How to use MFRC522 to create an RFID card reader security system
- Binary clock design based on FPGA
- Video doorbell design based on Raspberry Pi
- Smart car control system circuit design strategy
- Four water tower control schematic diagram
- Differential voltage or differential current alarm
- Music calendar using SMC6S37
- Enhanced password lock circuit using AE1169
- GW-0520CH-PS switching power supply circuit diagram
- High voltage centralized compensation capacitor circuit
- One of the inductive high voltage alarm circuits
- High voltage generator excitation group overvoltage protection circuit
- High voltage motor phase failure protection circuit
- Simple and efficient LED constant current drive circuit diagram
- High voltage linear regulator HIP5600 circuit
- High voltage and high current regulated power supply circuit diagram implemented with LM338
- High voltage step-down chopper stabilized power supply circuit
- High voltage Geiger counter power circuit
- Natural gas-gas-gasoline universal alarm
