Small capacitance and long duration timer circuit diagram
Source: InternetPublisher:supremeOne Keywords: Timer circuit circuit diagram WIDTH Updated: 2021/05/29
The small capacitance and long duration timer circuit is shown in the figure below. When a delay time of several hours is required, two dual-input precision level detectors CA3098 are used, and there is no need to use large-capacity, low-leakage capacitors. If Rc=22MΩ, RD=100KΩ, and CTK only needs 16μF, you can get a timer with a delay time of 4 hours.
ck="window.open(this.src)" alt="Click to see larger image" />
- Design and selection of electric control valve system drive
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Tutorial for building a remote-controlled Arduino Air-Boat
- An automated model railroad layout project using a microcontroller
- Motor automatic cycle control circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Light-controlled circuit design and analysis
- Common double-tube energy-saving lamp circuit schematic diagram
- Differential amplifier circuit diagram schematic diagram
- Video switching circuit diagram
- Ultrasonic transmitting circuit composed of discrete components
- Fuse/thin wire transmitter circuit diagram
- Field output circuit: TDA3654 circuit diagram
- The ever-changing sound and light analog controller circuit 02
- High efficiency LED driver circuit diagram
- Circuit using NCP1216 to drive LED
- Controllable voltage variable gain amplifier
