NE555 voltage doubler circuit, boost circuit
Source: InternetPublisher:清宁时光 Keywords: 555 circuit ne555 voltage doubler circuit Updated: 2020/08/07
Only using the timer IC555 to form a charge pump can obtain a high voltage of N times the power supply voltage. This is a voltage doubler rectification circuit composed of diodes and capacitors. The basic circuit is shown in Figure 1 (omitted). It is a combined unit of two diodes and two capacitors. Connect this unit to the output end of the 555 charge pump, as shown in Figure 2, to form a double voltage circuit. An output voltage that is twice the supply voltage can be obtained. Theoretically, (N+1) times the voltage can be obtained by connecting N units in series. However, in the actual circuit, since the output voltage of the 555 is slightly lower than the supply voltage, and each unit diode has a forward voltage drop VF, the output voltage of the voltage doubler circuit is lower than the theoretical value. For example, when the power supply voltage is +12V, the actual no-load output voltage from 2 times to 7 times the voltage will be lower than the theoretical value. Figure 3 is a 3x voltage circuit.
The output current capacity is about 20mA at 3 times the voltage, and the current decreases by 1/2 for each additional unit. The output voltage decreases as the output current increases. According to the component value of .555 in the figure, the oscillation frequency is about 950Hz.
![NE555 voltage doubler circuit, booster circuit NE555 Step-up converter](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/91b33712bc02a5aea0cbbd1f126e9df2.jpg)
![NE555 voltage doubler circuit, booster circuit NE555 Step-up converter](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/8a2dd191eec09cc0161e3b693f52e7cb.jpg)
- How are diodes made using semiconductors?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- In-depth analysis of energy losses in oscillation frequencies
- The Importance and Ideal Model of Impedance Matching
- How to read resistor color codes? Resistor color codes illustrated
- Analysis of the working principle of CMOS/CCD image sensor
- Causes of PCB deformation How to prevent circuit board bending and warping
- What is a Demultiplexer
- Make a simple AM radio with digital circuit
- ne555 temperature regulation circuit diagram
- NE555PWM pulse width modulation circuit
- 555 Oscillator: Two Tone Generator Circuit Diagram
- Cycle timer circuit diagram with start and stop preset functions
- Oscillation frequency is about 22KHz field mosquito repellent circuit diagram
- Light control circuit diagram using 555 time base circuit
- multi-tone alarm
- Flash circuit diagram with 555 circuit as the core
- Voltage polarity reversal circuit composed of 555 circuit
- Applying 555 circuit to transform the control circuit of foot-operated spot welding machine
