Flash circuit diagram with 555 circuit as the core
Source: InternetPublisher:containsmachine Keywords: 555 circuit circuit diagram flash circuit Updated: 2021/05/17
A low-frequency oscillation circuit made using a 555 time base circuit can form an interesting flashing light-emitting circuit. When the flash circuit with the 555 circuit as the core is working normally, the light-emitting diodes VD1 and VD2 will alternately flash in turn. The circuit principle is briefly described as follows: the time base circuit NE555 and R1, R2, and C1 form a low-frequency oscillator. After the circuit starts to oscillate, the potential of pin 3 of the time base circuit 555 changes continuously. When pin 3 is at high level, VD1 loses power and does not emit light, and VD2 is powered on and emits light; when pin 3 is at low level, VD1 is powered on and emits light, and VD2 loses power. Not glowing. Therefore, the two LEDs will flash and glow in turn. During specific production, the two light-emitting diodes are selected from red, green or yellow, and the difference can be more eye-catching.
- How does sand become chips?
- FPGA Features and Architecture
- Causes and solutions for noise in digital Class D amplifiers
- RC filter explained in detail
- DIY a decorative lamp
- Make a flameless electronic candle using simple electronics and LEDs
- Summary of knowledge points of multiplexer
- Introduction of TDA4863J/4863AJ TV field scanning IC
- LED Night Light
- LED Bicycle Lights
- How to learn circuit diagrams?
- 555 8-pin integrated circuit diagram
- A frequency meter circuit diagram composed of CD4046
- Pressure signal conditioning circuit circuit diagram based on MAX1450
- Cycle timer circuit diagram with start and stop preset functions
- Wireless frequency modulation (FM) microphone circuit diagram using Q5337
- A photoelectric control circuit diagram composed of 555
- Lithium battery fast charger circuit diagram design
- NE555 pin diagram and ne555 circuit application
- Applying 555 circuit to transform the control circuit of foot-operated spot welding machine
