Several practical circuit resistor-capacitor voltage reduction principles
Source: InternetPublisher:偷熊计划 Keywords: Rectification and filtering analog circuit resistance-capacitance step-down circuit diagram Updated: 2020/04/03
The conventional method of converting AC mains power to low-voltage DC is to use a transformer to step down the voltage and then rectify and filter it. When limited by factors such as size and cost, the simplest and most practical method is to use a capacitor step-down power supply.
The following points should be noted when using capacitors to reduce voltage:
1. Select the appropriate capacitor based on the current size of the load and the operating frequency of the AC, rather than the voltage and power of the load.
2 The current-limiting capacitor must be a non-polar capacitor, and electrolytic capacitors must not be used. And the withstand voltage of the capacitor must be above 400V. The most ideal capacitor is an iron-shell oil-immersed capacitor.
3 Capacitor voltage reduction cannot be used under high power conditions because it is unsafe.
4 Capacitive voltage reduction is not suitable for dynamic load conditions.
5 Likewise, capacitive voltage reduction is not suitable for capacitive and inductive loads.
6. When DC operation is required, try to use half-wave rectification. Bridge rectification is not recommended. Moreover, constant load conditions must be met.
circuit one,
![Several practical circuit resistor-capacitor voltage reduction principles](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/79c846536765bbb511d3f1c7038759dd.jpg)
This type of circuit is usually used to obtain non-isolated low-current power supplies at low cost. Its output voltage can usually range from a few volts to thirty tens of volts, depending on the Zener voltage regulator used. The amount of current that can be provided is proportional to the current limiting capacitor capacity. When using half-wave rectification, the current (average value) obtained per microfarad capacitor is: (SI unit)
I(AV)=0.44*V/Zc=0.44*220*2*Pi*f*C
=0.44*220*2*3.14*50*C=30000C
=30000*0.000001=0.03A=30mA
If full-wave rectification is used, double the current (average value) can be obtained:
I(AV)=0.89*V/Zc=0.89*220*2*Pi*f*C
=0.89*220*2*3.14*50*C=60000C
=60000*0.000001=0.06A=60mA
Generally speaking, although the full-wave rectification of this type of circuit has a slightly larger current, its stability and safety are worse than that of the half-wave rectification type because it is floating, so it is used less often.
When using this circuit, you need to pay attention to the following things:
1. It is not isolated from 220V AC high voltage, please pay attention to safety and be careful to prevent electric shock!
2. The current-limiting capacitor must be connected to the live wire, the withstand voltage must be large enough (greater than 400V), and a series of anti-surge and insurance resistors and parallel discharge resistors must be added.
3. Pay attention to the power consumption of the zener tube, and it is strictly forbidden to disconnect the zener tube.
circuit two,
![Several practical circuit resistor-capacitor voltage reduction principles](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/08e2e5a752ffea8a71017c0832f29d17.jpg)
The simplest capacitor step-down DC power supply circuit and its equivalent circuit are shown in Figure 1. C1 is a step-down capacitor, generally 0.33~3.3uF. Assuming C1=2uF, its capacitive reactance XCL=1/(2PI*fC1)=1592. Since the on-resistance of the rectifier is only a few ohms, the dynamic resistance of the voltage regulator VS is about 10 ohms, the current limiting resistor R1 and the load resistor RL are generally 100~200, and the filter capacitor is generally 100uF~1000uF, and its capacitive reactance is very Small and can be ignored. If R is used to represent the equivalent resistance of all components except C1, the AC equivalent circuit of the figure can be drawn. At the same time, the condition of According to electrical principles, it can be known that the relationship between the average value of the rectified DC current Id and the average value of the AC current I is Id=V/XC1. If C1 is in uF, then Id is in milliamps. For 22V, 50 Hz AC, Id=0.62C1 can be obtained.
From this, the following two conclusions can be drawn: (1) When using a power transformer as a rectified power supply, after the parameters in the circuit are determined, the output voltage is constant, while the output current Id changes with the increase or decrease of the load; ( 2) When using a capacitor to step down the voltage as a rectifier circuit, since Id=0.62C1, it can be seen that Id is proportional to C1, that is, after C1 is determined, the output current Id is constant, but the output DC voltage varies with the load resistance RL. changes within a certain range. The smaller RL is, the lower the output voltage is, and the larger RL is, the higher the output voltage is. The value of C1 should be selected based on the load current. For example, the load circuit requires a 9V working voltage and the average load current is 75 mA. Since Id=0.62C1, C1=1.2uF can be calculated. Considering the loss of the voltage regulator tube VD5, C1 can be taken as 1.5uF. At this time, the actual current provided by the power supply is Id=93 mA.
The voltage stabilization value of the voltage regulator tube should be equal to the working voltage of the load circuit, and the selection of its stable current is also very important. Since the capacitor step-down power supply provides a constant current, which is approximately a constant current source, it is generally not afraid of the load being short-circuited. However, when the load is completely open, a full 93 mA current will pass through the R1 and VD5 loops, so the maximum stability of VD5 The current should be 100 mA. Since RL is connected in parallel with VD5, while ensuring that RL draws 75 mA of operating current, there is still 18 mA of current passing through VD5, so its minimum stable current must not be greater than 18 mA, otherwise the voltage stabilizing effect will be lost.
The value of the current limiting resistor cannot be too large, otherwise it will increase the power loss and also increase the voltage resistance requirement of C2. If R1=100 ohms, the voltage drop on R1 is 9.3V, then the loss is 0.86 watts, and a resistor of 100 ohms and 1 watt can be used.
The filter capacitor is generally 100 microfarads to 1000 microfarads, but attention should be paid to the selection of its resistance. As mentioned before, the load voltage is 9V, the voltage drop on R1 is 9.3V, and the total voltage drop is 18.3V. Considering the remaining There is a certain margin, so the C2 withstand voltage should be above 25V.
circuit three,
![Several practical circuit resistor-capacitor voltage reduction principles](http://www.eeworld.com.cn/circuit/upload/1a24951da50bd95a181c85a24d358480/27a3e75e7f1017f3e5fd36e5747b9143.jpg)
As shown in Figure-1, C1 is a step-down capacitor, D2 is a half-wave rectifier diode, and D1 provides discharge to C1 during the negative half cycle of the mains power.
In the loop, D3 is the zener diode R1 and is the charge discharge resistor of C1 after turning off the power supply. In practical applications, the circuit shown in Figure 2 is often used. When it is necessary to provide a larger current to the load, the bridge rectifier circuit shown in Figure 3 can be used. The unstabilized DC voltage after rectification will generally be higher than 30 volts, and will fluctuate greatly with changes in load current. This is due to the large internal resistance of this type of power supply, so it is not suitable for large current power supply. application occasions.
Device selection
1. When designing the circuit, you should first determine the accurate value of the load current, and then refer to the example to select the capacity of the step-down capacitor. Because the current Io provided to the load through the buck capacitor C1 is actually the charge and discharge current Ic flowing through C1. The greater the capacity of C1 and the smaller the capacitive reactance Xc, the greater the charge and discharge current flowing through C1. When the load current Io is less than the charge and discharge current of C1, excess current will flow through the voltage regulator tube. If the maximum allowable current Idmax of the voltage regulator tube is less than Ic-Io, it will easily cause the voltage regulator tube to burn out.
2. To ensure that C1 can work safely, its withstand voltage should be greater than twice the power supply voltage.
3. The selection of the discharge resistor R1 must ensure that the charge on C1 is discharged within the required time.
Design examples
In Figure-2, it is known that C1 is 0.33μF and the AC input is 220V/50Hz. Find the maximum current that the circuit can supply to the load.
The capacitive reactance Xc of C1 in the circuit is:
Xc=1 /(2 πf C)= 1/(2*3.14*50*0.33*10-6)= 9.65K
The charging current (Ic) flowing through capacitor C1 is:
Ic = U / Xc = 220 / 9.65 = 22mA.
Usually the relationship between the capacity C of the step-down capacitor C1 and the load current Io can be approximated as: C=14.5 I, where the capacity unit of C is μF and the unit of Io is A.
Capacitor step-down power supply is a non-isolated power supply. Special attention should be paid to isolation during application to prevent electric shock.
The unstabilized DC voltage after rectification will generally be higher than 30 volts, and will fluctuate greatly with changes in load current. This is because this type of power supply has a large internal resistance, so it is not suitable for large current power supply. application situations.
The working principle of capacitor voltage reduction is not complicated. Its working principle is to use the capacitive reactance generated by the capacitor at a certain AC signal frequency to limit the maximum operating current. For example, under the power frequency condition of 50Hz, a 1uF capacitor generates The capacitive reactance is about 3180 ohms. When an AC voltage of 220V is applied to both ends of the capacitor, the maximum current flowing through the capacitor is about 70mA. Although the current flowing through the capacitor is 70mA, no power consumption is generated on the capacitor. It should be that if the capacitor is an ideal capacitor, the current flowing through the capacitor is the imaginary current, and the work it does is reactive power. According to this characteristic, if we connect a resistive component in series with a 1uF capacitor, then the resistor The voltage obtained across the resistive component and the power consumption it generates completely depend on the characteristics of the resistive component. For example, we connect a 110V/8W light bulb in series with a 1uF capacitor, and then connect it to a 220V/50Hz AC In terms of voltage, the bulb is lit and emits normal brightness without being burned. Because the current required by a 110V/8W bulb is 8W/110V=72mA, it is consistent with the current limiting characteristic generated by the 1uF capacitor. In the same way , we can also connect a 5W/65V light bulb and a 1uF capacitor in series to the 220V/50Hz AC, and the light bulb will also be lit without being burned. Because the operating current of the 5W/65V light bulb is also about 70mA. Therefore, capacitor voltage reduction actually uses capacitive reactance to limit current. The capacitor actually plays the role of limiting the current and dynamically distributing the voltage across the capacitor and load.
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Working principle and truth table of JK flip-flop
- How does RCCB work?
- How to build a triangle wave generator using an op amp and discrete components
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Make a simple AM radio with digital circuit
- LED Night Light
- Crystal controlled local oscillator circuit diagram
- Transistor circuit diagram explanation
- Operational amplifier circuit analysis of virtual open and virtual short
- Introduction and application of microelectronic tube 6C6B
- Zener diode white noise generator circuit
- Low frequency voltage amplifier circuit diagram
- AN7177 power amplifier circuit diagram
- NE5532 operational amplifier circuit diagram
- 3V rectifier filter power supply
- School bell analog circuit
