Bridge rectifier circuit diagram and current reversal
Source: InternetPublisher:公子李 Keywords: Diode full wave rectifier analog circuit bridge rectifier circuit Updated: 2021/07/09
Bridge rectifier circuit is the most commonly used rectifier circuit. This circuit, as long as two diode ports are added to form a "bridge" structure, will have the advantages of a full-wave rectifier circuit and at the same time overcome its shortcomings to a certain extent.
Figure (a) is a bridge rectifier circuit diagram, and (b) is a simplified drawing.
![Figure (a) is a bridge rectifier circuit diagram, and (b) is a simplified drawing.](http://www.eeworld.com.cn/circuit/upload/b6d057d6e185e9816a0d1c1d73b3912e/b31d568aa3ba4aafaaccee548bab8741.jpg)
Current direction of bridge rectifier
![Circuit direction of bridge rectifier circuit](http://www.eeworld.com.cn/circuit/upload/b6d057d6e185e9816a0d1c1d73b3912e/6ddf6a245c88002ab05545a43ebf9d55.jpg)
In the positive half cycle of u2, D1 and D3 are turned on, and D2 and D4 are turned off. The current returns from the upper end of the TR secondary to the lower end of the TR secondary through D1 → RL → D3, and a half-wave rectified voltage is obtained on the load RL.
In the negative half cycle of u2, D1 and D3 are cut off, D2 and D4 are turned on, and the current returns from the lower end of the Tr secondary through D2 → RL → D4 to the upper end of the Tr secondary, and the other half-wave rectified voltage is obtained on the load RL.
In this way, a voltage waveform that is the same as that of full-wave rectification is obtained on the load RL, and the calculation of its current is the same as that of full-wave rectification, that is
UL = 0.9U2
IL = 0.9U2/RL
The average current flowing through each diode is
ID = IL/2 = 0.45 U2/RL
The maximum reverse voltage that each diode can withstand is
What is silicon bridge and what is bridge stack?
At present, the four rectifier diodes of a low-power bridge rectifier circuit are connected into a bridge and packaged into a rectifier device, called a "silicon bridge" or "bridge stack". It is easy to use, and the rectifier circuit is often simplified as shown in Figure Z Figure 1 (c) form.
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- Analysis of the basic principle of measuring resistance by bridge method
- Types and structures/characteristics/functions/implementations of smart sensors
- Transfer characteristics of BJT, how to apply Shockley equation?
- Working principle and truth table of JK flip-flop
- Basic characteristics/working principles and application circuits of tunnel diodes
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Ceramic filter structure/working principle/characteristics/application
- Build a musical fountain using Arduino and sound sensor
- What is the difference between JFET and MOSFET
- Can you use the new high-voltage thyristors and diodes?
- Power diode analysis
- Wireless microphone circuit
- Acousto-optic digital level detector circuit diagram
- Microcontroller controlled flash circuit
- Input status indication circuit diagram
- AC voltmeter
- Diode Balanced Mixer Circuit
- Working principle diagram of electronic transformer
- Incandescent lamp step-down circuit
