Electronic amusement machine principle circuit diagram
Source: InternetPublisher:aytwartoofyoroo Keywords: Power DC/DC Updated: 2021/09/30
Today I will share with you the principle circuit of an electronic amusement machine. The circuit mainly resets IC2 by pressing SB2 by the host, and VD1A-VD9A do not emit light. The person who points out the prize points out which position of the prize (such as No. 5), then the host closes the switch S5 to make VD5B light up. Then the person who clicks the prize presses SB1, and IC3 is called to play the congratulatory message "Gong Xi Fa Cai". At the same time, the oscillation circuit starts to oscillate, and its pulse signal acts on the CP terminal of IC2, and VD1A-VD9A flashes rapidly in the clockwise direction. When SB1 is released, IC1 and IC3 stop working because the power supply is cut off. At this time, only one of VD1A-VD9A is lit or all are extinguished. If VD5A happens to light up, it will light up at the same position as VD5B, and the prize will be awarded successfully. As shown below.
- Introduction and principle analysis of switching regulated power supply
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- LED rechargeable flashlight circuit diagram
- Dual forward converter schematic diagram
- Boost drive circuit composed of RT8450
- USB power socket using the car battery
- Converting a lithium battery charging board into a constant voltage and current charger
- MIC4680 constant current charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Circuit diagram explanation: simple switching power supply circuit diagram
- DC output DC converter circuit
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Ten circuit designs for precision full-wave rectification
- A typical application circuit diagram of PS61040
- STR5412 power circuit
- Uninterruptible power supply circuit diagram composed of MIC5158
- Power circuit a composed of intelligent thyristor modules
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
