LM317T safety application circuit
Source: InternetPublisher:吃掉星星 Keywords: Application circuit LM317T BSP output voltage Updated: 2021/09/07
When using LM317T to make an adjustable regulated power supply, poor contact of the potentiometer often causes the output voltage to rise and burn the load .
If a triode is added (as shown in the figure below), under normal circumstances, the base potential of T1 is 0 and T1 is turned off .
It has no effect on the circuit; when W1 has poor contact, the base potential of T1 rises. When it rises to 0.7V, T1 turns on .
Lowering the adjustment terminal voltage of LM317T will also lower the output voltage, thereby protecting the load. If removed
When the transistor is disconnected from the center point of W1, the small 3.8V bead burns out immediately, and the measured output voltage is as high as 21V. And add some
At T1, the brightness of the small beads decreases. At this time, the output voltage of LM317T is only 2V, thus effectively protecting the load.
- How to Make a Soft Latch Circuit
- ISO113 circuit that can reduce power consumption
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Simple and practical LED lamp driving circuit
- Detailed explanation of 5v charger circuit diagram
- How to use SBR to improve power conversion efficiency
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- Converting a lithium battery charging board into a constant voltage and current charger
- Circuit diagram explanation: simple switching power supply circuit diagram
- Self-defense anti-riot circuit
- Fish pond oxygenation reminder circuit
- Fish farming thermostatic control circuit
- Rural fish farming control circuit
- Particle clogging alarm circuit of wheat seeder
- Agricultural spraying and insecticide control circuit
- Inductive feedback oscillator circuit
- Second-order active band-stop filter circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Digital stopwatch display circuit
