Touch switch to control the circuit of power on and off
Source: InternetPublisher:兰博 Keywords: power supply LED switch Updated: 2021/01/31
In the picture, a 74HC74 digital IC is used. Pin 14 is connected to the positive pole of the power supply, and pin 7 is connected to the negative pole of the power supply. The power supply voltage range is 2-6V. When the button is pressed once, the LED lights up and switches once.
- How about the boost converter TPS61299?
- Build a simple buck-boost regulator and test it on a breadboard
- Basic connection circuit of signal and power supply composed of ISOll3
- Constant current LED lamp driver circuit with soft start and anti-shock
- How to use SBR to improve power conversion efficiency
- Low cost and high performance LED constant current power supply
- Dual forward converter schematic diagram
- A small and easy-to-make fast charger
- 3~15V 10A adjustable voltage regulated power supply
- UC3842 Electric Vehicle Charger
- Teach you a thyristor dimming LED drive power circuit design
- LED drive circuit based on switching power supply
- Ambulance electronic flash signal circuit diagram
- LT3755 driver LED application circuit diagram
- Dark activated LED flash circuit
- 38 LED energy-saving lamp circuit
- Leakage alarm automatic control socket circuit diagram
- MEMS strobe driver circuit diagram
- Paper thickness measurement circuit
- Medicine bottle assembly line counting circuit
