Timing circuit that prohibits restarting
Source: InternetPublisher:拿铁三分糖 Keywords: Power communication power Updated: 2020/12/30
![Timing circuit that prohibits restarting](http://www.eeworld.com.cn/circuit/upload/9f28e0fee786c8c9fdf32526f29552bd/cfe3ba499d551b8d81629943e2067c2b.jpg)
The above figure shows an underground oxygen concentration detection circuit, which can be used in underground operating environments to detect the oxygen concentration in the air. The oxygen concentration detection sensor in the circuit converts the detection result into a DC voltage. After passing through the circuit amplifier ICl-1 and the voltage comparator ICl-2, it drives the transistor and rri, and then rri drives the relay. After the relay operates, the contact is connected. , the buzzer sounds to remind people that the oxygen concentration is too low, attracting people's attention.
- Sharing layout and tips for multi-rail power supply design
- A very convenient small power supply circuit to share
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LNK304 non-isolated LED light string driver circuit
- Dynamic power supply for power amplifier controlled by thyristor
- An ultra-low output voltage regulator
- USB power socket using the car battery
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Circuit diagram explanation: simple switching power supply circuit diagram
- Portable device charging power circuit design
- Voltage stabilization control circuit in power circuit
- Commonly used power circuits in printers
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Warm current power circuit a
- Simple dual-channel variable DC power supply circuit
- Diamond differential input power amplifier power circuit
- audio power circuit
- AC-DC conversion power supply-inverter power supply circuit
