High frequency equivalent circuit diagram of resistor
Source: InternetPublisher:通通 Keywords: Power supply other power circuits Updated: 2021/03/18
Resistors are the most widely used components in PCBs. Commonly used resistors include carbon, wire-wound and film chip resistors. Wire-wound resistors are not suitable for high-speed and high-frequency circuit applications due to the excessive lead inductance. Thin film chip resistors are often used in circuits, but they also have hidden radio frequency characteristics. The figure shows the high-frequency equivalent circuit of a resistor with a nominal value R.
![12.jpg](http://www.eeworld.com.cn/circuit/upload/7a6b75d6fa370e37084ed5146bef3d96/b7906ec92fd6726473ceaabca07ea5cd.jpg)
Figure high frequency equivalent circuit of resistor
As shown in the figure, L is the inductance of the two metal pins; the capacitor Ca is the parasitic capacitance inside the resistor; Cb is the parasitic capacitance between the two metal pins (negligible). The two most easily overlooked aspects of resistors are package size and internal parasitic capacitance. Different packages have different parasitic parameters. Generally speaking, smaller "SMD" packages have smaller parasitic parameters. For example, the 0603 package is more suitable for high-speed high-frequency circuits than the 1206 package.
- How to Make a Soft Latch Circuit
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- ISO113 circuit that can reduce power consumption
- Low cost and high performance LED constant current power supply
- Dual forward converter schematic diagram
- Voltage-current converter constructed with XTR110
- An ultra-low output voltage regulator
- Integrated regulated power supply with continuously adjustable output voltage
- Adjustable voltage regulated power supply circuit
- Teach you a thyristor dimming LED drive power circuit design
- How to turn on the power with LLC controller?
- Take stock of wonderful designs
- Determining the prerequisites for successful circuit board design
- A design plan for a serial communication interface circuit
- Car glass hail melting circuit design
- An operational amplifier with very high amplification
- volumeter
- simple audio mixer
- Clock switching circuit and its precautions
