Overvoltage automatic power-off device
Source: InternetPublisher:aytwartoofyoroo Updated: 2015/10/04
This article introduces an overvoltage protection circuit made by the switching integrated circuit TWH8778, which can avoid the danger caused by excessive mains voltage. The circuit principle is shown in the attached figure. The 220V mains power provides a stable 12V working voltage for the switch integrated circuit through C1, VD1, and DW1. VD3, R2, and RP1 form a voltage dividing sampling circuit. When the mains voltage is normal, DW2 cannot conduct, the working voltage of pin 5 of TWH8778 is lower than 1.6V, relay J does not pull in, and the mains supplies normal power to the CZ socket through the J-1 normally closed contact; when the mains voltage is high When out of the normal setting, DW2 breaks down and conducts, the potential of pin ⑤ of TWH8778 rises to 1.6V, causing the IC to flip, pin ③ outputs high level, the relay is closed, and the power supply of the electrical appliance is cut off immediately, thus avoiding overvoltage. Hazards caused by using electrical appliances.
After the device is welded correctly, connect the mains power to the input end of the voltage regulator, and carefully adjust RP1 with the voltage regulator so that relay J closes when the voltage is 240V. Then connect the circuit to the mains power grid and it can work normally. .
![过压自动断电装置](http://www.eeworld.com.cn/circuit/upload/538a1bc8a409ff500dc8e0cb6c6d7ecb/d273d494-3c63-11ec-9384-086126841eb8.jpg)
Latest Control Circuits Circuits
- DIY a simple fire alarm
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Manual automatic air compressor control circuit
- Design and production of radio remote control fan stepless speed regulator
- Temperature control circuit design and analysis
- PIC microcontroller controlled remote anti-theft alarm circuit
- Water supply reminder after water outage
- Vibration anti-theft alarm circuit
- "Watchdog" anti-theft alarm circuit
Popular Circuits
- fire smoke control circuit
- Mobile phone camera flash control circuit
- Switching regulated power supply circuit
- Water dispenser double sheet control circuit
- Assembly line outage monitoring circuit
- 24h automatic switching capacitor control circuit
- Digital current loop control circuit
- Relay control circuitb
- Forward and reverse control circuit of micro DC motor a
- Power supply circuit with multiple outputs (MAX1902)
