Design of loop-powered thermocouple temperature measurement circuit
Source: InternetPublisher:containsmachine Keywords: Temperature measurement loop powered thermocouple Updated: 2020/03/12
This article brings you a 14-bit 4-20mA loop-powered thermocouple temperature measurement system circuit design diagram. This circuit is a complete loop-powered thermocouple temperature measurement system that uses a precision analog microcontroller. The PWM function controls 4 mA to 20 mA output current. Offers the advantage of higher resolution PWM driving 4mA to 20mA loops, supporting T-type thermocouples with a temperature range of −200° C to +350° C.
Circuit functions and advantages
The circuit shown in Figure 1 is a complete loop-powered thermocouple temperature measurement system that uses the PWM function of a precision analog microcontroller to control a 4 mA to 20 mA output current.
Figure 1. ADuCM360 controls 4 mA to 20 mA loop-based temperature monitoring circuit.
Circuit principle : This circuit integrates most of the circuit functions on the precision analog microcontroller ADuCM360, including a dual-channel 24-bit Σ-Δ ADC, an ARM Cortex™-M3 processor core, and a control loop voltage up to 28 The PWM/DAC feature of the 4 mA to 20 mA loop of V provides a low-cost temperature monitoring solution. In it, the ADuCM360 is connected to a T-type thermocouple and a 100Ω platinum resistance temperature detector (RTD). RTD is used for cold junction compensation. The low-power Cortex-M3 core converts the ADC readings into temperature values. The supported temperature range for Type T thermocouples is −200° C to +350° C, and the temperature range is 4mA to 20mA. This circuit has the advantage of driving a 4mA to 20mA loop with higher resolution PWM. PWM based output provides 14-bit resolution. The circuit is powered by the ADP1720 linear regulator, which regulates the loop power supply to 3.3 V to provide power for the ADuCM360, operational amplifier OP193, and optional reference voltage source ADR3412.
- Which one is better, NPN or PNP transistor?
- How do Zener diodes protect circuits?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- How to calculate the value of capacitors in parallel?
- Why use PWM? What are its advantages?
- Important things to know about PCB routing and how to design the right routing for your PCB
- How to install the accelerometer
- LED Bicycle Lights
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- An example of proportional integral circuit diagram
- Intelligent fire alarm system circuit module design drawing
- Design of loop-powered thermocouple temperature measurement circuit
- Two-wire temperature measurement-frequency converter
- RTD temperature measurement-voltage and current output circuit
- Temperature measurement and control circuit
- Temperature measurement bridge circuit
- Temperature measurement control circuit
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
