RTD temperature measurement-voltage and current output circuit
Source: InternetPublisher:ohahaha Keywords: Temperature measurement output circuit voltage and current BSP Updated: 2020/09/14
When the distance between the RTD temperature sensor and the amplifier is relatively long,
issues such as the sensor's lead resistance and the vulnerability of the leads to interference cannot be ignored. The circuit shown in the figure can solve this problem.
This circuit uses a voltage-4-20mA current converter XTR103. XTR103 is a dedicated signal processing circuit for RTD.
It integrates Rrl'D linearization circuit internally and expands the power supply voltage range to +9~+40V.
XTR103 outputs two 0.8mA current sources. The current sources are driven by VT2 and then added to the RTD to avoid
attenuation caused by the line and suppress line interference. The function of Rh is similar to that of R in XTR101. The function is exactly the same: limiting
the maximum value of the output current. Rini is a linear adjustment resistor, which can change the resistance value to change the linearity. The output signal
gets a current of 4~20mA after being connected to the external transistor VT1. RCV420 is a 4-20mA current-to-voltage dedicated converter (
will be introduced in "3" of this section), which outputs a 0~5V voltage after conversion.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- The Importance and Ideal Model of Impedance Matching
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Working principle and truth table of JK flip-flop
- Diode-based clipping circuit
- Basic characteristics/working principles and application circuits of tunnel diodes
- Touch circuit design and analysis
- Simple LED advertising light circuit
- LED Night Light
- Experiment and production of NE555 time base integrated circuit
- Electronic thermometer circuit
- Inpatient pager circuit
- soil content measurement circuit
- Proportional frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Double gate field effect transistor high frequency amplifier circuit
- High and low frequency signal generator circuit
- Motorcycle flash light circuit
