Volume control circuit
Source: InternetPublisher:spectrum Updated: 2019/10/30
Based on the classic Baxendall tone control circuit, this provides a maximum cut and boost of around 10dB at 10K and 50Hz. As the controls are passive, the last transistor provides a slight boost. The output is designed to feed an amplifier with input impedance of 10k to 250k.
- How to use a microcontroller to control a servo motor?
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Peripheral circuit of automotive motor controller power supply chip
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Using P110C to control 6 DC motors simultaneously
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Light-controlled circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- Homemade short circuit alarm device
- Infrared detection alarm
- Multi-channel patrol detection control circuit a
- Water and electricity saving infrared control circuit
- Photocell amplification control circuit
- Switching regulated power supply circuit
- Assembly line outage monitoring circuit
- sound control circuit
- Relay control circuit a
- Temperature measurement and control circuit
- Typical electronic volume control circuit
- Small signal to large current photoelectric control circuit
