2W audio amplifier
Source: InternetPublisher:三岁就很酷 Updated: 2014/01/20
his was one of the earliest circuits that I ever designed and built, in Spring 1982. At that time I had only an analogue meter and a calculator to work with. Although far from perfect, this amplifier does have a wide frequency response, low distortion, and is capable of driving an 8 ohm speaker to output levels of around 5 watts with slightly higher distortion. Any power supply in the range 12 to 18 Volts DC may be used.
Circuit Description
The amplifier operates in Class AB mode; the single 470R preset resistor controls the quiescent current flowing through the BD139/140 complimentary output transistors. Adjustment here, is a trade-off between low distortion and low quiescent current. Typically, under quiescent conditions, standby current may be 15 mA rising to 150 mA with a 50 mV input signal.
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How to identify common mode interference? Methods to eliminate common mode interference
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- What is the difference between CPLD and FPGA?
- Why use PWM? What are its advantages?
- Structural diagram and function of sliding resistor
- Introduction of TDA4863J/4863AJ TV field scanning IC
- LED Night Light
- An example of proportional integral circuit diagram
- 555 square wave oscillation circuit
- 555 photo exposure timer circuit diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- 555 electronic guide speaker circuit diagram for blind people
- Circuit diagram of disconnection alarm composed of 555
- Analog circuit corrector circuit diagram
- color discrimination circuit
- Color sensor amplification circuit
- Level indication circuit
