Power switch control circuit diagram
Source: InternetPublisher:兰博 Keywords: Power switch voltage regulator Updated: 2021/01/28
This circuit uses 50 BUZ23 field effect transistors in parallel. The blocking voltage of the tubes is 100V. The required control power is extremely small, and there will be no secondary breakdown and positive temperature coefficient of the conduction section. Since the current in the entire circuit is very large, 50 gate resistors and components are connected in parallel.
In order to discharge the energy stored in the load loop wire inductance, an absorption loop consisting of 20 RC elements connected in parallel is connected between the drain and the source.
![Power switch control circuit diagram](http://www.eeworld.com.cn/circuit/upload/2008ddf35785dc71bc1eb4e9eea97b33/0d2c31bc99be0e46e245aea0542310b4.jpg)
- Analysis of the working principle of switching regulator
- The basic principles of power supply design. What are the key components of a power supply?
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Isolated two-wire current loop circuit (XTR101, ISO100)
- A small and easy-to-make fast charger
- Electric bicycle battery charger circuit
- Constant current charger using light emitting diode as voltage regulator
- The production of adjustable voltage-stabilized power supply composed of LM317
- Battery powered switching circuit diagram
- STR5412 power circuit
- Power circuit of STR5412
- Industrial X-ray flaw detector delay control switch circuit diagram
- Fixed and switching hybrid regulated power supply electronic circuit diagram
- Schematic diagram of a sound and light dual control energy-saving switch circuit
- DC 12V to AC 100V inverter power supply circuit design
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Class A power amplifier power circuit
- Antenna amplifier synchronous power supply circuit
