Duty cycle adjustable frequency multiplier
Source: InternetPublisher:同住地球村 Keywords: Frequency multiplier trigger pulse signal Updated: 2021/01/31
Shown is a duty cycle adjustable multiplier. It is composed of low-power monostable and astable multivibrator CD 4047, diodes, resistor-
capacitor components, etc. Rr, cl, R2, and C2 respectively form an integrating loop, which is used to detect the leading and trailing edges of the input pulse signal . That is to
say, the front and rear edge instantaneous spike signals output by the two integrating loops trigger the negative trigger terminal - IR and the positive trigger terminal +TR of CD4047 respectively. Therefore, CD4047 outputs a pulse signal
from the Q terminal with a frequency twice that of the input signal . Potentiometer W (100 kfl) can be used to change
the duty cycle of the output pulse signal sequence. Figure 19-18 shows the pin arrangement of chip CD 4047.
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Types and structures/characteristics/functions/implementations of smart sensors
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Working principle and truth table of JK flip-flop
- How to build a triangle wave generator using an op amp and discrete components
- Make a simple AM radio with digital circuit
- LED Bicycle Lights
- Experiment and production of NE555 time base integrated circuit
- An example of proportional integral circuit diagram
- Pulse signal generation and display circuit b
- Counter composed of 4 T flip-flops
- Bistable circuit triggered by count input
- Pulse signal generating circuit c
- Zero trigger thyristor power adjustment circuit 2
- Zero trigger integrated circuit temperature control circuit 2
- Zero trigger integrated circuit temperature control circuit one b
- vacuum cleaner circuit
- Accurate second pulse signal generation circuit diagram
- Pulse frequency multiplier circuit diagram
