Pressure measurement and AD conversion circuit using single power supply
Source: InternetPublisher:明天见 Keywords: Single power supply pressure measurement conversion circuit BSP Updated: 2021/01/26
In portable measuring instruments, it is often inconvenient to use AC power. In this case,
a negative power generator must be added to the measurement circuit using dual power supplies. The circuit as shown in the figure uses a single power supply for pressure measurement and A/D. Conversion
circuit, its function is to amplify the sensor measurement signal to 0~5V and then convert it into a digital signal (A/D conversion).
The output signal of the pressure sensor measuring bridge is sent to the ① and ② pins of the IC. After internal amplification, it outputs a voltage of 0~5V, and
then sent to the A/D converter IC3 for analog-to-digital conversion, and finally outputs an 8-bit digital signal. The gain of the circuit is 333.3 (because
pin ⑩ is grounded), and RP adjusts the bridge excitation voltage so that the output voltage is 0~5V (because the maximum input voltage of digital circuits is generally
5v).
Since the 1832 needs to work under dual power supply conditions, a multivibrator composed of a timing circuit 555 is introduced. The
oscillation output signal is coupled through C3 and rectified by VDJ and VD2 to form a DC negative voltage on C2, which serves as the negative voltage of IC1.
power supply.
- What is a photocoupler and how to select and use one?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- An article explains the working principle of the Wheatstone bridge
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- This article will tell you the hard requirements of operational amplifiers
- The Importance and Ideal Model of Impedance Matching
- What are the types of commonly used batteries?
- What is a D flip-flop and how does it work?
- Analysis of three simple electronic dice circuits
- Tutorial on building a NOT gate using BJT transistors
- Fish pond oxygenation reminder circuit
- Peanut and melon seeds roasting machine circuit
- Greenhouse temperature control circuit
- DC ammeter
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- superheterodyne radio circuit
- Fault signal trip circuit
