Remote RTD temperature sensing-voltage and current output conversion circuit
Source: InternetPublisher:念慈菴 Keywords: Temperature sensing voltage and current conversion circuit BSP Updated: 2020/01/28
When the distance between the RTD temperature sensor and the amplifier is relatively long,
issues such as the sensor's lead resistance and the vulnerability of the leads to interference cannot be ignored. The circuit shown in the figure can solve this problem.
This circuit uses a voltage-4-20mA current converter XTR103. XTR103 is a dedicated signal processing circuit for RTD.
It integrates Rrl'D linearization circuit internally and expands the power supply voltage range to +9~+40V.
XTR103 outputs two 0.8mA current sources. The current sources are driven by VT2 and then added to the RTD to avoid
attenuation caused by the line and suppress line interference. The function of Rh is similar to that of R in XTR101. The function is exactly the same: limiting
the maximum value of the output current. Rini is a linear adjustment resistor, which can change the resistance value to change the linearity. The output signal
gets a current of 4~20mA after being connected to the external transistor VT1. RCV420 is a 4-20mA current-to-voltage dedicated converter (
will be introduced in "3" of this section), which outputs a 0~5V voltage after conversion.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- Types and structures/characteristics/functions/implementations of smart sensors
- How does sand become chips?
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Transfer characteristics of BJT, how to apply Shockley equation?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Simple LED advertising light circuit
- Pulse therapy circuit
- soil content measurement circuit
- Particle clogging alarm circuit of wheat seeder
- Wien bridge oscillator circuit
- Crabo oscillator circuit
- Inductive feedback oscillator circuit
- Broadband high frequency power amplifier circuit
- Double gate field effect transistor high frequency amplifier circuit
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
