Basic application circuit of thermistorb
Source: InternetPublisher:风向双子座 Keywords: thermistor application circuit BSP Updated: 2021/10/01
The basic application circuit of the thermistor is shown in the figure .
Figure (a) shows the most basic temperature measurement circuit. The temperature measurement accuracy of this circuit is not high and can only be used in
situations where accuracy requirements are not high. When RT is a positive temperature coefficient thermistor, when the temperature increases, the output voltage vo increases, and vice versa;
when RT is a negative temperature coefficient thermistor, when the temperature increases, the output voltage vo decreases, and vice versa.
Figure (b) is a thermistor temperature difference measurement circuit using an operational amplifier, and the temperature measurement accuracy is improved. This
circuit can detect the temperature difference between two points. When the temperature at RTi is lower than the temperature at RT2, that is, RTi <RT2, the potential of
terminal (1) of the operational amplifier is higher than the potential of terminal (+), and the output is low level; In the same way, when the temperature of month L is higher than the temperature
of RT2 , the output is high level.
Figure Il (c) is a temperature measurement circuit using an operational amplifier and a logarithmic diode. The logarithmic diode
compensates for the linearity of the thermistor , and RP can adjust the gain of the amplifier, thereby further improving the output characteristics.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- This article will tell you the hard requirements of operational amplifiers
- The Importance and Ideal Model of Impedance Matching
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What is a D flip-flop and how does it work?
- Beautiful crown wreath made with LED
- Important things to know about PCB routing and how to design the right routing for your PCB
- How to build a triangle wave generator using an op amp and discrete components
- What is a Demultiplexer
- Set timing circuit when power is on
- Homemade disinfectant circuit
- Egg warming circuit
- Particle clogging alarm circuit of wheat seeder
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Domestic KD8041 integrated phase locked loop
- Proportional frequency discriminator circuit
- Wien bridge oscillator circuit
- Wireless microphone circuit
- color discrimination circuit
