Battery fast charging control integrated circuit design
Source: InternetPublisher:公子李 Keywords: charging control fast charging battery integrated circuit design Updated: 2021/11/02
Circuit principle: The circuit provides +5V power supply voltage by a transformer, diode and voltage regulator IC7805. The battery voltage is divided by resistors R5 and R6 and then sent to the BAT end of the chip to provide a sampling voltage. The resistance of the resistor voltage divider network input to the BAT terminal should not be less than 200kΩ. When the TM terminal is grounded, the corresponding fast charge charging rate is 1C and the fast charge replenishment time is 80 minutes.
![Battery fast charging control integrated circuit design](http://www.eeworld.com.cn/circuit/upload/9fc5d19749f180063cdfa2f4b611117d/0c7aeb03dcf64a9e2dbb49954b0f8e04.jpg)
- Sharing layout and tips for multi-rail power supply design
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- Transformerless AC-DC constant current LED driver circuit
- Detailed explanation of 5v charger circuit diagram
- A simple positive and negative power supply circuit
- 3~15V 10A adjustable voltage regulated power supply
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Detailed explanation of mobile phone charger circuit diagram
- An analysis of low quiescent current in the most common small battery-powered devices
- Analysis of lithium-ion batteries that won’t catch fire
- Low quiescent current is an extended battery system
- Battery fast charging control integrated circuit diagram
- One of the battery fast charging circuits
- Lithium-ion battery charging control module PS1719 circuit
- Quick charging device circuit for walkie-talkie
- CD4541 cadmium nickel battery automatic charging circuit diagram
- Cadmium-nickel battery short circuit quick eliminator (1)
- Fast charging circuit diagram using UC3906
