Simple level conversion circuit diagram
Source: InternetPublisher:JFET Keywords: Circuit diagram level conversion circuit transistor logic level Updated: 2021/12/19
The level shifting circuit consists of fast switching transistors Q1 and Q2. The user selects level shifting high and shifting low, which are the DC bias voltages connected to the emitters of the transistors to match the desired output high logic level. and low logic level . C1, R1, D1, C2, R2 and D2 keep the base voltage of Q1 and Q2 close to the emitter voltage.
![Simple level conversion circuit diagram](http://www.eeworld.com.cn/circuit/upload/3090238919e0ec691184a8ed0a9669f1/ecd5b1c29e78f14651f729cfc1feeac4.jpg)
- Analysis of the working principle of switching regulator
- Build a simple buck-boost regulator and test it on a breadboard
- Recommended circuits for different power on times of LM4911
- Single-power supply circuit for ISO122P/ISO124
- Principles and precautions of active discharge circuit
- USB power socket using the car battery
- Production of backup power supply for cordless phone
- MAX1811 Lithium Battery Charger Production
- A low-cost, high-reliability battery charger for electric vehicles
- LM317T voltage regulation adjustable circuit diagram explanation
- One of three signal switches, multi-way switch CD4027 multi-way switch
- Ultrasonic receiver circuit diagram for echo detection distance
- superheterodyne radio circuit
- Touch switch power circuit
- Internal structure of DTL inverter circuit
- Distributed parameter microstrip circuit
- Alarm circuit for induction cooker
- Bridge motor drive circuit
- 32kHz transistor clock oscillator
- AC power supply non-stop switching circuit using transistors c
