Controller circuit for automatically changing wind speed to 10 degrees (C192, 555, CD4028)
Source: InternetPublisher:张三叔 Keywords: Control Circuit Updated: 2024/09/03
As shown in the figure, it is a control circuit for automatically changing 10 wind speeds. The circuit includes a clock signal generator IC1, a counter IC2, a decoder IC3, a synchronous phase shift circuit (BG1, BG2, BG3), a thyristor control circuit SCR, a step-down rectifier circuit, etc. The voltage after step-down rectification is stable at (9-10.5)V, providing power for the entire controller.
The clock signal generator is a multivibrator composed of IC1 (555), R2, R3, W1, W2, C3, etc. The signal frequency depends on the charge and discharge time constant, and the frequency and duty cycle of the signal can be changed by adjusting W1 and W2. The low-frequency square wave generated by IC1 is used as the counting pulse of IC2 and added to the CP terminal (pin 14). The 4-bit binary code A, B, C, D generated by the corresponding decimal synchronous counter IC2 (C192) is added to the decimal decoder IC3 (CD4028). With the addition of CP, the decoded BCD code is high level at the output terminals Q0, Q1...Q8, Q9 in turn, thus providing a basis for automatic conversion of wind speed gears.
The synchronous phase shift circuit can change the signal output by IC3 in sequence, thereby changing the conduction angle of the thyristor SCR, causing the motor terminal voltage to change in sequence, and realizing automatic conversion of 10 wind speeds.
- Timed chicken coop door opener
- Digital volume control
- Dual-channel infrared relay controller
- Refrigerator door open alarm
- Speed limit alarm
- Solar panel controller
- High-loudness piezoelectric alarm buzzer
- How Dual Operational Amplifiers Work in Motor Drive Applications
- Typical layout and detailed introduction of open collector switching circuit
- Infrared wireless remote control water dispenser
- Schematic diagram of motor PLC control circuit
- PLC chain alarm control circuit used in production process
- Digital current loop control circuit
- Typical operation display circuit
- Galanz rice cooker control circuit
- Forward and reverse control circuit of micro DC motor a
- Micro DC motor steady speed control circuit a
- Voltage servo motor and control circuit
- Temperature detection control circuit for vegetable greenhouses
- Button type electronic volume control circuit
京公网安备 11010802033920号
