Single-phase protection circuit for high-voltage motors
Source: InternetPublisher:张三叔 Keywords: Protection circuit piezoelectric motor high voltage Updated: 2021/02/20
When the single-phase grounding current of the high-voltage motor
reaches 5A, single-
phase grounding protection should be installed, and the wiring is as shown in the figure.
The operating current Inp (E) of the single-phase grounding protection should be set according to the capacitive current k
of
the motor , that is, The tuning calculation
formula is
Iop(E)=k. 1 XJm/Ki
In the formula, ki - the reliability coefficient of the protection device, takes
the conversion ratio of 4-5, K, -TAN.
The operating current of single-phase grounding protection can also
be set approximately according to the sensitivity coefficient Sp of the protection (usually 1.5), that is,
k (E) = (L- h,)/KiSp
where L - and the high-voltage current The motor stator winding is electrically connected to
the single-phase ground capacitance current of the entire power grid;
- How to use a microcontroller to control a servo motor?
- The meaning and importance of circuit protection, common types of circuit protection
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Design of an autonomous plant watering system using ATtiny85
- Peripheral circuit of automotive motor controller power supply chip
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Light-controlled circuit design and analysis
- Night dog barking anti-theft reminder circuit
- Transistor leakage release protection circuit
- Low voltage blocking overcurrent protection circuit
- Overload protection circuit for high-voltage motors
- Thyristor silicon stack protection circuitb
- Thyristor resistance-capacitance protection circuit a
- Star connection motor phase failure protection circuit
- Thyristor type overcurrent protection circuit 3
- Mains undervoltage and overvoltage protection circuit three
- One of the mains undervoltage and overvoltage protection circuits
- Three-phase AC power supply phase sequence protection circuit
