Digital password lock circuit composed of CD4520
Source: InternetPublisher:柯南道尔 Keywords: Combination lock CD4520 Updated: 2024/08/19
As shown in the figure, the universal digital password lock circuit is composed of CMOS digital integrated circuits, which are characterized by wide power supply voltage range, low power consumption, good anti-interference performance, and few peripheral components. The password lock has a total of 256 password combinations and is equipped with a pseudo code switch, which has good security characteristics. Its circuit composition is shown in the figure. The password lock circuit is composed of a dual binary synchronous add counter CD4520, which contains two binary counters with the same structure. Each counter has 4 output terminals: Ql~Q4, a pulse rising edge trigger terminal CP; a falling edge trigger terminal EN non, and a reset terminal R. The two counters share a positive power supply terminal and a negative power supply terminal.
- AC power failure alarm
- Drain pump controller
- Light-controlled/dark-controlled relay switch
- Countdown relay timer
- Novel motor Y-△ control step-down starting circuit
- How to use a discarded game controller as a speaker wire controller
- Easy to make light controlled delayed flash toy car
- Brushless DC Motor Control Principle
- Homemade high-frequency head switching switch
- Circuit diagram of the electronic bird singing sweetly
- Electric plow control circuit
- Differential amplifier emitter negative feedback gain control circuit
- Electronic rhythm control circuit
- Paper tension control circuit
- Microwave oven control circuit
- Digital current loop control circuit
- Forward and reverse control circuit of micro DC motor a
- Simple phone code lock circuit
- Two-digit code lock
- Telephone dial doubles as password lock circuit diagram
京公网安备 11010802033920号
