Various DA converters with simple structuresb
Source: InternetPublisher:elleny Keywords: converter BSP D/A converter Updated: 2020/02/20
In digital products, their output or display circuits often take the form of analog signals, so digital systems also require some D/A converters
with
simple structures . The figure shows the circuit structure of various D/A converters
used when speed and accuracy are not high . Their function is
to convert the digital signal output by the integrated circuit into an analog voltage signal.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- How to identify common mode interference? Methods to eliminate common mode interference
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- FPGA Features and Architecture
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- Diode-based clipping circuit
- electromagnetic field sensor
- Self-defense anti-riot circuit
- stuttering correction circuit
- Smoking Cessation Circuit
- Inpatient pager circuit
- Soil water shortage prompt circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
- superheterodyne radio circuit
