Addition circuit
Source: InternetPublisher:司马缸砸光 Keywords: Arithmetic circuit BSP resistor Updated: 2021/06/21
The addition circuit generally adopts the inverting input method, that is,
the inversion addition circuit. It is based on the inverting input operational amplifier circuit, and the signal
voltage
to be added is connected
to the inverting input terminal of the operational amplifier through a resistor .
The addition circuit is shown in Figure 7-5. This is an
inverting addition circuit with three input signals. The input signals
8ii, 2, and 1113 are all input from the inverting input terminal N, the pin is
a feedback resistor, and the non-inverting input terminal P is grounded through the balancing resistor R4
. The resistance value of the balancing resistor R4 should be
the parallel sum of Ri, R2, R3 and Rr. The output voltage of
the addition circuit is equal to the sum of the input voltages of each branch. This
structure can realize the addition of multiple input signals .
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Datasheet/Pinout/Technical Specifications of LMC555
- Beautiful crown wreath made with LED
- Basic characteristics/working principles and application circuits of tunnel diodes
- Causes of PCB deformation How to prevent circuit board bending and warping
- Important things to know about PCB routing and how to design the right routing for your PCB
- Star finder battery indicator circuit
- LED Night Light
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- Voice controlled flash LED light circuit diagram
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Egg warming circuit
- Crop anti-frost circuit
- Fish farming thermostatic control circuit
- Biogas concentration detection line
- Digital stopwatch display circuit
- Small current generator circuit
- Sine wave signal generator circuit
