Touch delay switch power supply circuit
Source: InternetPublisher:jikai233 Keywords: Touch delay switch switching power supply circuit Updated: 2020/11/20
Shown is the touch delay switch power supply circuit. When the hand touches the touch chip, it is equivalent to giving a trigger signal to the base of VT1 to turn it on
, so VI2 is also turned on, and the power supply charges the capacitor cz through VT2. When the charging voltage is high enough, VT2 is cut off, VT3 is turned on, and VT4 is
also turned on. Then it is turned on, and the bulb emits light and illuminates. When the charge on C2 is slowly released, vr3 is cut off. VT4 also cuts off causing the light bulb to go out.
- How to identify common mode interference? Methods to eliminate common mode interference
- How does sand become chips?
- FPGA Features and Architecture
- What is power factor and three ways to improve it
- Share an interesting LED decoration project
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Important things to know about PCB routing and how to design the right routing for your PCB
- Make a simple AM radio with digital circuit
- Circuit diagram of a differential amplifier circuit
- Tongzhou CDVB3188V receiver switching power supply circuit
- Output 12V-10A power supply circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Push-pull switching power supply circuit
- Flyback switching power supply circuit 01
- Series switching power supply circuit composed of CW3524 02
- DC-DC conversion switching power supply circuit
- Single line in and out delay switch circuit
- Experimental switching power supply circuit
- Long delay switch circuit diagram
