L type winding tap speed regulating motor
Source: InternetPublisher:闪电杰克 Keywords: motor winding speed regulation coil Updated: 2021/03/14
The speed regulation of electric fan motors mostly uses winding coil
taps, which actually means changing the number of winding coils, thereby
changing the intensity of the magnetic field generated by the stator coil and achieving speed adjustment.
The figure shows the winding structure of a wall-mounted electric fan motor. There are two taps in the running winding, so that a three-
speed variable electric fan motor can be realized . Since the two sets of coils are connected in an L-letter shape, it is also called an L-shaped winding structure.
- DIY a simple fire alarm
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- A small improvement to the temperature and water level indicator alarm
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Design and analysis of the principle of automatic power-off switch during power outage
- Light-controlled circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- Bicycle anti-theft alarm
- Mobile phone camera flash control circuit
- time control circuit
- Water dispenser double sheet control circuit
- Car window control circuit
- sound control circuit
- Schematic diagram of motor PLC control circuit
- Sprinkler control circuit using AC motor
- Temperature detection control circuit of electric hot water bottle
- Voltage servo motor and control circuit
- Button type electronic volume control circuit
