Square wave generator circuit using NAND gate integrated circuit 74LS00
Source: InternetPublisher:spectrum Keywords: Integrated circuit NAND gate square wave generator generator circuit Updated: 2020/07/13
Shown is a square wave generator circuit composed of NAND gate integrated circuit 74LSOO . Among them, NAND gates 1 and 2 and external
RC time constant components form an oscillation circuit, and NAND gate 3 is a buffer output stage. As long as the capacity of C is changed, square
wave output of different frequencies can be obtained. Table 16-1 shows several examples of how variable capacitance C changes the oscillation frequency for reference.
- Signal diode arrays/configurations, freewheeling diode operation
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- How to identify common mode interference? Methods to eliminate common mode interference
- How to read resistor color codes? Resistor color codes illustrated
- Analysis of the working principle of CMOS/CCD image sensor
- Basic characteristics/working principles and application circuits of tunnel diodes
- Tutorial on building a NOT gate using BJT transistors
- How to install the accelerometer
- What is a Demultiplexer
- Make a simple AM radio with digital circuit
- Small current generator circuit
- Ultrasonic transmitter circuit b composed of UCM-40-T and 74LS00 NAND gate
- Bird call analog signal generator circuit
- trigger pulse generator circuit
- Several improved sawtooth wave generator circuits - bootstrap circuit with voltage stabilization feedback
- Use CD4011 to make a sound and light dual control delay lamp (2)
- MC4024P simply constructs a signal generator circuit diagram
- Absolute value function generator circuit with controllable output signal polarity
- Noise generator circuit
- Pulse stretching circuit using a NAND gate
