trigger pulse generator circuit
Source: InternetPublisher:MartinFowler Keywords: pulse generator trigger generator circuit single pulse Updated: 2020/01/13
Shown is a trigger pulse generator circuit. The circuit consists of shuttle key switch, double D flip-flop SN7474 and NAND gate.
D flip-flop works in shift mode. Each time the button is pressed, a low level is sent to the Dl terminal in the figure, and the Dl state is shifted to the right bit by bit under the action of the clock signal CP
. When the second rising edge of CP arrives, the NAND gate forms a single pulse output from the Q1 and Q2 states. The voltage shown in the figure moves into a low level,
so the output is a negative single pulse .
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- How does sand become chips?
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Diode-based clipping circuit
- DIY a decorative lamp
- Share an interesting LED decoration project
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Digital number selection machine
- Home appliance repair signal generator circuit
- square wave generator circuit
- Tone generator circuit
- Siren signal generator circuit
- TV grid signal generator circuit
- Absolute value function generator circuit with controllable output signal polarity
- Pulse signal generator circuit composed of LM359
- Pulse signal generator circuit composed of CMP-04
- D flip-flop type single pulse generator
- Single pulse generation circuit diagram
