The working principle of common emitter amplifier circuitd
Source: InternetPublisher:笑流年 Keywords: Common emitter amplifier circuit output voltage Updated: 2021/08/22
After the signal passes through the common emitter amplification unit circuit, it outputs an inverse amplified signal. Its working principle is shown in the figure. When analyzing, we
can consider the change curve of the input signal as the change curve of the input current . In the 1/4 cycle, the current is increasing. According to
the amplification function of the transistor IC-18IB, it can be seen that the current is also increasing. According to Ohm's law URC=ICRC, seven f. Then URC f, then from the output voltage
UR
on the load RL , = VCC-URC can be obtained·sevent, URC t, Vcc remains unchanged, Uk, J. That is, the output curve is as shown in Figure 1-7 (a)
. The other cycles are similarly shown in Figure (b) (c) (d). It can be seen that the output voltage is opposite in phase to the input voltage.
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What does a rectifier do? What is the process of rectification?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- How to calculate the value of capacitors in parallel?
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Tutorial on building a NOT gate using BJT transistors
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Touch circuit design and analysis
- Simple LED advertising light circuit
- STR5412 power circuit
- DC/DC converter LTC3441
- Current reduction protection voltage stabilizing circuit
- Typical relaxation oscillator and output voltage triangle wave
- The working principle of common emitter amplifier circuitc
- Transistor common emitter amplifier circuit a
- One of the bipolar regulated power supply circuits using SW1468 voltage regulator block
- High-stability regulated power supply circuit for digital-to-analog conversion
- The basic form of frequency equalization circuit
- The excitation power supply of the resolver is composed of a single OPA2541
