The working principle of common emitter amplifier circuitc
Source: InternetPublisher:吃掉星星 Keywords: Common emitter amplifier circuit output voltage Updated: 2021/02/22
After the signal passes through the common emitter amplification unit circuit, it outputs an inverse amplified signal. Its working principle is shown in the figure. When analyzing, we
can consider the change curve of the input signal as the change curve of the input current . In the 1/4 cycle, the current is increasing. According to
the amplification function of the transistor IC-18IB, it can be seen that the current is also increasing. According to Ohm's law URC=ICRC, seven f. Then URC f, then from the output voltage
UR
on the load RL , = VCC-URC can be obtained·sevent, URC t, Vcc remains unchanged, Uk, J. That is, the output curve is as shown in Figure 1-7 (a)
. The other cycles are similarly shown in Figure (b) (c) (d). It can be seen that the output voltage is opposite in phase to the input voltage.
- Does lithium iron phosphate battery need a protection board? The correct way to charge lithium iron phosphate battery
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Advantages and disadvantages of organic semiconductors, the conductive mechanism of organic semiconductors
- What are the classifications of filters?
- Share an interesting LED decoration project
- Build a musical fountain using Arduino and sound sensor
- How to build a triangle wave generator using an op amp and discrete components
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Experimental circuit based on 4040 binary adder counter
- STR5412 power circuit
- DC/DC converter LTC3441
- Current reduction protection voltage stabilizing circuit
- Typical relaxation oscillator and output voltage triangle wave
- The working principle of common emitter amplifier circuitc
- Transistor common emitter amplifier circuit a
- One of the bipolar regulated power supply circuits using SW1468 voltage regulator block
- High-stability regulated power supply circuit for digital-to-analog conversion
- The basic form of frequency equalization circuit
- The excitation power supply of the resolver is composed of a single OPA2541
