What does power ripple mean? How big is the DDR power ripple requirement?
Source: InternetPublisher:aerobotics Keywords: DC/DC switching power supply module power ripple Updated: 2025/02/28
The power supply ripple index is a very important parameter of the switching power supply module or DC/DC.
Power ripple can be understood as the fluctuation of the output voltage of the power module including VRM, which has nothing to do with the complex power supply network, or the fluctuation of the voltage at the source end of the power supply output. It is a periodic signal that fluctuates up and down around the output DC voltage, but the period and amplitude are not fixed, but change with time, and the ripple waveforms of different power supplies are also different.
What is the DDR power supply ripple requirement?
Generally it does not exceed 1%. DDR3 is generally 1.5V, so the ripple cannot exceed 15mV and so on. If it is too high, it will not reach high frequency!
What is Ripple?
The output of a switching power supply is not truly constant, and there is periodic jitter in the output, which looks like water ripples and is called ripple. The ripple can be voltage ripple or current ripple.
Power ripple
Low-frequency ripple: It comes from the cycle of AC input. The power supply’s rejection ratio to input is not perfect. When the input changes, the output will also change.
High-frequency ripple: It comes from the switching cycle. The switching power supply does not output energy linearly and continuously, but transmits the energy in packets. Therefore, there will be ripples corresponding to the switching cycle.
- Analysis of transistor voltage-stabilized power supply circuit diagram
- Methods for Suppressing Conducted Radiation in the FM Band
- What effect does the copper coating on the bottom of the inductor have on the power supply?
- How to transfer electricity from the source to the energy storage system?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Step-down power supply for driving relays
- Switching power supply circuit composition and function introduction of each part
- Using CW34603 to form a circuit to change the polarity of the output power supply
- A small and easy-to-make fast charger
- An ultra-low output voltage regulator
- Excellent performance household inverter power supply circuit
- EPSON PHOTO 830U printer power circuit
- Commonly used power circuits in printers
- 2-phase CPU power circuit using HIP6301 and HIP6601 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- KGDS type single-phase low temperature iron plated power supply circuit
- Transistor stabilized current power supply circuit 2
- CF1 (CF2) DC power supply circuit
- Power circuit for home appliance repair
- Wide input 350mA LED driver circuit based on NCL30000
