Principle analysis and demonstration program of deceleration stepper motor 28BYJ-48
Source: InternetPublisher:spectrum Keywords: Stepper Motor Updated: 2024/10/14
The schematic diagram of the reduction stepper motor 28BYJ-48 is shown below:
The middle part is the rotor, which is composed of a permanent magnet, and the side is the stator winding. When one winding of the stator is energized, an electromagnetic field in one direction will be generated. If the direction of this magnetic field is not in the same straight line as the direction of the rotor magnetic field, then the magnetic fields of the stator and rotor will generate a torque to twist the stator.
By changing the magnetic field of the windings in sequence, the stepper motor can be made to rotate forward or reverse (for example, the power-on sequence is A->B->C->D for forward rotation, and vice versa). By changing the time interval of magnetic field switching, the speed of the stepper motor can be controlled. This is the driving principle of the stepper motor.
Since the driving current of the stepper motor is relatively large, the microcontroller cannot drive it directly. It is generally driven by the ULN2003 Darlington array. Of course, it can also be driven by a pull-down resistor or a transistor, but the effect is not so good and the torque generated is relatively small.
The stepper motor demonstration program is as follows:
#include <reg52.h>
sbit key=P2^0; //Button controls the direction of the stepper motor
unsigned char speed=5; //Stepper motor speed
//Eight-beat drive, the order is A AB B BC C CD D DA
unsigned char code cLOCkWise[]={0x01,0x03,0x02,0x06,0x04,0x0c,0x08,0x0d};
void delay(unsigned char z)
unsigned char x,y;
for(x=0;x<z;x++)
for(y=0;y<110;y++);
void main()
unsigned char i;
while(1)
for(i=0;i<8;i++)
if(key) //Button not pressed, forward rotation
P0=clockWise[i];
delay(speed);
else //Button pressed, reverse rotation
P0=clockWise[8-i];
delay(speed);
- What are the advantages of solid-state relays? Solid-state relay insulation monitoring design scheme
- How to judge the quality of insulation of low-voltage motors?
- Model rocket launch controller circuit
- Build a glove-controlled robotic arm
- Tutorial for building a remote-controlled Arduino Air-Boat
- A simple door handle touch alarm circuit
- An automated model railroad layout project using a microcontroller
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Add one more component to improve the phase failure protection function
- Light-controlled circuit design and analysis
- Agricultural spraying and insecticide control circuit
- Multi-channel patrol detection control circuit c
- Switching regulated power supply circuit
- Chandelier control circuit
- 24h automatic switching capacitor control circuit
- Detection and control circuit of electromagnetic stove
- Timing and fire power control circuit
- Temperature detection control circuit for vegetable greenhouses
- Temperature measurement and control circuit
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
