Torque motor driving welding electrode circuit
Source: InternetPublisher:太白金星 Keywords: Motor drive torque motor BSP Updated: 2021/08/28
It can be used for welding the connection between the motor armature
winding end and the commutator (the wire
diameter of the armature is 0. 1-0. 7mm, and the maximum outer diameter of the commutator
is 50mm). Of course, it can also be used to
connect other wires, etc. In the pressure welding
between the armature winding end and the commutator of the welded motor
, the welding current, welding time and welding electrode
pressure are the three main process parameters that require adjustment
. The pressure of the welding electrode depends on
the locked-rotor torque of the torque motor . The locked-rotor torque
is proportional
to the current flowing through its armature , so as long as
the current (or armature voltage) is adjusted, the pressure of the welding electrode on the object to be welded can be adjusted.
- Sharing layout and tips for multi-rail power supply design
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- In-depth analysis of DC-AC converter inverter
- Fabrication of multi-cell lithium battery charging circuit
- Practical and convenient fax machine power supply control circuit
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dual forward converter schematic diagram
- Charging control circuit made by solar energy
- Homemade Electric Bike Fast Charger
- Pulse therapy circuit
- Homemade disinfectant circuit
- Fish farming thermostatic control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Broadband high frequency power amplifier circuit
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
- Color display circuit
- Digital stopwatch display circuit
- Various signal generator circuits
