Safe and reliable electronic touch switch
Source: InternetPublisher:吃掉星星 Keywords: Touch switch Updated: 2024/09/29
The circuit is shown in the figure above. IC is a D flip-flop CD4013 (a CD4013 can form two electronic touch switches), forming a bistable circuit. M is the induction electrode. When the M is touched by hand, the human body's clutter induction signal is added to the trigger end of IC through R1. Its positive pulse signal causes IC to flip, and the Q end outputs a high level. Its Q end has enough output current to drive the bidirectional thyristor SCR to turn on. Connect 220V AC power, and the electrical appliances in the socket BX work. If the M is touched again, the CL end gets a positive pulse again, IC flips again, the Q end becomes a low level, the SCR is cut off, and the electrical appliances lose power and stop working. Diodes D1 and D2 provide discharge circuits for C1 and C2 to eliminate the "jitter" phenomenon and ensure that IC flips once the M is touched.
The IC circuit uses a 6V dry battery to make it safe to work at low voltage. SCR uses 3A/600V bidirectional thyristors such as TLC336. M needs to be made of phosphor copper sheets. The circuit can work without debugging.
The picture below is the printed circuit board of this circuit.
- DIY a simple fire alarm
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- A small improvement to the temperature and water level indicator alarm
- Squirrel cage asynchronous motor reverse braking control circuit
- Temperature control circuit design and analysis
- Audio interface protection circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Homemade short circuit alarm device
- Precious home appliance anti-theft alarm
- Agricultural spraying and insecticide control circuit
- Multi-channel patrol detection control circuit b
- Photoelectric tracking control circuit
- Ringtone control circuit
- Switching regulated power supply circuit
- Electromagnet control circuit
- Galanz rice cooker control circuit
- Range hood detection control circuit
- Electric heater temperature detection control circuit
- Micro DC motor steady speed control circuit a
