Frequency divider that converts 50Hz or 60Hz frequency into 1/60 frequency (CD4040)
Source: InternetPublisher:super_star Keywords: Crossover Updated: 2024/10/25
As shown in the figure, this is a frequency division circuit that converts 50Hz or 60Hz frequency into 1/60 frequency. Due to the high integration and multiple levels of CMOS, a CMOS integrated circuit can be used to divide the 50Hz or 60Hz signal to generate a pulse output with a period of 1 minute. This circuit uses a 12-level counter CD4040AE, which can convert the 50Hz input pulse signal into a pulse output with a period of 1 minute, and the frequency division coefficient is 50×60=3000. The method of converting the decimal number 3000 into binary is to divide 3000 by 2 continuously, and record all even numbers as "0", and odd numbers as "1", and discard the numbers below the decimal point until the quotient is equal to 1, so the corresponding binary "101110111000" is obtained. Obviously, a seven-input NAND gate is required for decoding, that is, one pulse is output for every 3000 input pulses.
- What is the difference between MOSFET and BJT? Which one is better between MOSFET and BJT?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- FPGA Features and Architecture
- What is the difference between CPLD and FPGA?
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- How to calculate the value of capacitors in parallel?
- Analysis of three simple electronic dice circuits
- Structural diagram and function of sliding resistor
- What types of force sensors are there?
- What is the difference between JFET and MOSFET
- Precision timer circuit composed of LM567 and MP1826
- The second circuit mode of the frequency divider
- Frequency divider circuit with adjustable frequency division ratio
- Frequency divider circuit diagram
- Third order active filter
- Frequency divider composed of flip-flops
- Shift register type divider by 12
- square wave divider
- TTL integrated crystal oscillator and frequency divider
- Hi-Fi loudspeaker 3-way and 4-way crossovers
