Scalable MAX610 output current regulated power supply circuit a
Source: InternetPublisher:国民男神经 Keywords: Stabilized power supply circuit output current voltage regulator tube Updated: 2020/01/03
The maximum output current of the AX610 series is IO M =lOOmA. The output current can be expanded by adding a voltage regulator tube . Two voltage regulator tubes (2CW106, U: about 8.2V) are connected in series with reverse polarity; Figure 14-72 (b) Connect one Only
1N592281. 5W/7. 5V voltage regulator tube .
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Driving circuit of switching power supply field effect tube
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Driving circuit that controls LED brightness using PWM signal
- Simple and practical LED lamp driving circuit
- Voltage-current converter constructed with XTR110
- Boost drive circuit composed of RT8450
- Adjustable regulated power supply with current limiting protection
- LM317 regulated power supply
- How to Select Modular EMI Filters for AC-DC Converters
- Power circuit of STR5412
- Power circuit of LBO-522 dual trace oscilloscope
- Voltage stabilization control circuit in power circuit
- Output 12V-10A power supply circuit
- Three-way DC-DC converter circuit
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Single phase thyristor slotless nickel plated power circuit
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Diamond differential input power amplifier power circuit
