Light emitting diode display circuit 2b
Source: InternetPublisher:国民男神经 Keywords: LED display circuit BSP capacitor step-down Updated: 2021/09/29
Light-emitting diodes can also use capacitors to reduce voltage . If capacitors are used to reduce voltage, the power consumption of the entire circuit is almost close to
that of the light-emitting diodes. However, when using capacitors to reduce voltage, some measures must be taken to prevent the light-emitting diodes from breakdown due to the instantaneous voltage impact of the capacitors. The circuit
using AC drive and capacitor voltage reduction is shown in Figure 13-2.
The selection of components is as follows: the diode VD uses 1N4001 to protect the light-emitting diode
(reverse voltage);
for the AC 220V power supply, the capacitor Cl uses polyester capacitor o. lptF/400V, C2 selects BP type bipolar capacitor 22"F/
16V as the absorption branch of the instantaneous impulse current, circuit R selects 2.ZMfl, 1/8W resistor; as the
discharge , resistor R selects 6. 2k0, 1/2W resistor.
- Digital level display (CD40147, CD4511)
- Use NE555 to make a touch self-extinguishing table lamp
- SC3071 touch step dimming light circuit
- Lighting audio control circuit
- Gift lamp music box circuit
- Microwave Doppler warning circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Mains undervoltage and overvoltage alarm circuit 2
- Touch/wireless remote control dimmer light circuit diagram
- 6-digit cathode fluorescent triode display circuit
- Analysis of rectifier circuit types and principles
- Electronic anti-asthma circuit
- Physiotherapy ventilator circuit
- Peanut and melon seeds roasting machine circuit
- Biogas concentration detection line
- Double detuned loop frequency discriminator circuit
- ring amplitude modulation circuit
- Audio function generator composed of ICL8038
- Series crystal oscillator
- color discrimination circuit
