Multi-purpose thyristor rectifier and speed regulating circuit
Source: InternetPublisher:MartinFowler Keywords: Rectifier thyristor speed regulating circuit BSP Updated: 2020/06/27
This power supply has the following uses.
① Provide a 0-220V adjustable DC power supply, which can be used to adjust the speed of tens of kilowatts of DC motors. In addition,
a 170V 3A non-adjustable DC power supply is provided, which can be used as the excitation power supply of the DC motor or the arc starting power supply of the electric welding machine.
②After appropriate switching, a low voltage and high current of 350V, O~lfl;OA can be supplied for DC welding.
In the figure, voltage relay KAi is used to prevent overcurrent when the motor reverses at high speed; voltage loss relay KA2 is used to
protect against loss of excitation and prevent overrun.
- Analysis of the working principle of car garage door lights
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Motor self-starting circuit
- Design and production of wireless multi-location control switch circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of voice control circuit
- Electric vehicle battery charging protection circuit
- Homemade short circuit alarm device
- Simple disconnection burglar alarm
- Set timing circuit when power is on
- Voice controlled flash LED light circuit diagram
- Crop anti-frost circuit
- Fish farming thermostatic control circuit
- Farmland irrigation automatic control circuit a
- Varactor Diode Frequency Modulator
- Voltage-controlled voltage source second-order active low-pass filter circuit
- color discrimination circuit
- Power phase sequence display circuit
- Home appliance repair signal generator circuit
