DC motor reversible speed regulation circuit that changes excitation direction
Source: InternetPublisher:奥特man123 Keywords: Excitation DC motor reversible speed regulation speed regulation circuit Updated: 2021/08/09
Reversible speed regulation of a DC motor can be achieved by changing the direction of the excitation current or by changing the direction of the armature current
The circuit is shown in Figure 16-87. It is suitable for reversible speed regulation of small and medium-power DC motors , especially in situations where starting is frequent and
reversal is infrequent. This circuit can start directly at full speed without causing overcurrent.
Adjust the potentiometer RPi to change the voltage negative feedback amount; adjust RP3 and RP2 to change the current cutoff negative feedback intensity
; adjust the master potentiometer RR to change the motor speed.
- How to use a microcontroller to control a servo motor?
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Working principle of one Xipu STR soft starter controlling two motors
- Motor self-starting circuit
- Add one more component to improve the phase failure protection function
- Light-controlled circuit design and analysis
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Magnetic door and window anti-theft alarm
- Password type motorcycle anti-theft device
- Differential amplifier emitter negative feedback gain control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Photocell trigger control circuit
- Water dispenser double sheet control circuit
- Electromagnetic brake control circuit
- Small DC motor irreversible speed regulation circuit 2
- Third harmonic excitation circuit
- Phase compound excitation circuit
- DC electromagnet strong excitation fast pull-in circuit 5
- Synchronous motor full voltage starting circuit
