One of the zero-trigger thyristor power adjustment circuits
Source: InternetPublisher:张小哥 Keywords: Thyristor trigger Updated: 2020/01/28
The output waveform of the thyristor zero trigger circuit is a sine wave, so it does not produce electromagnetic interference like the phase shift trigger circuit
This is the basic circuit for zero trigger thyristor power regulation . In the figure, the voltage regulator tube VS
acts as a clamp and provides a path for charging the capacitor Ci; the function of VD is to prevent the capacitor Cz from reverse charging during the negative half cycle of the power supply; the resistors
Rz and R4 are current-limiting resistors to limit the control electrode current. In the figure, the power-on time 1 and the power-off time 2 depend on
the opening and closing time of the switch (or control contact) SA. That is, the load power is controlled by SA .
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Design and selection of electric control valve system drive
- Use your smartphone to turn on/off the power in your home
- Controlling LEDs with Node-RED in Raspberry Pi
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- A simple door handle touch alarm circuit
- Manual automatic air compressor control circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Audio interface protection circuit
- Motorcycle anti-theft device circuit design
- Micro remote control receiving and control circuit
- Car window control circuit
- Automatic tuning control circuit
- Typical operation display circuit
- Electric heater temperature detection control circuit
- Taifu DK2-25 rice cooker temperature detection control circuit
- Water dispenser (Aucma) temperature detection control circuit
- Wide input range non-synchronous voltage mode control circuit
- 35W half-wave resistor-capacitor phase-shift trigger actuation control circuit
- Apply LOGO! Electric gate control circuit b
