One of the current cutoff feedback circuits
Source: InternetPublisher:消失的歌 Keywords: BSP electric motor Updated: 2020/12/07
In order to prevent the thyristor from being damaged due to excessive current during motor
starting, overload, forward and reverse rotation, etc. in the speed control system
, a current cutoff feedback circuit needs to be introduced. The principle is: when the armature current exceeds a certain value, the feedback voltage is added to
the input end of the transistor amplifier, so that the conduction angle of the thyristor decreases rapidly, thereby reducing the current to protect the tube.
The circuit is shown in Figure 16-37. It is suitable for speed regulating circuits
of small capacity motors below 5kW . Adjust the potentiometer RPi so that when the armature current exceeds the limiting current
value, the voltage regulator tube VS breaks down.
- Servo motor pin diagram/working principle/application
- Use your smartphone to turn on/off the power in your home
- DIY an electromagnetic levitation device
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Simple phase failure protection circuit composed of intermediate relay
- Add one more component to improve the phase failure protection function
- Design and analysis of wire control circuit
- Light-controlled circuit design and analysis
- Set timing circuit when power is on
- High-efficiency speaker circuit for rural stage
- Fish farming thermostatic control circuit
- Agricultural spraying and insecticide control circuit
- Soil water shortage prompt circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Diode balanced amplitude modulation circuit
- Color display circuit
- Guest arrival signal recognition circuit
- Digital stopwatch display circuit
