Small transistor trigger circuit output through pulse transformer Part 3
Source: InternetPublisher:走马观花 Keywords: Transistor pulse transformer trigger circuit phase shift Updated: 2021/07/13
This circuit is also a monostable DC switching circuit that uses a switching
circuit composed of small thyristors to amplify the input pulse. Features of this circuit: The output is a wide pulse with adjustable width. The phase shift range is determined by the phase shift
range
of the input pulse . By adjusting the resistance of resistor Ri, the charging speed of Cl can be changed, that is, the pulse width can be changed.
- A simple magnetic switch circuit sharing
- The meaning and importance of circuit protection, common types of circuit protection
- Tutorial on making your own remote-controlled robotic arm
- How to set up a cheap beam break sensor control distance scene using a reflector
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Motor self-starting circuit
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and production of no-load automatic power-off device for household power supply
- Infrared blocking alarm device
- Homemade disinfectant circuit
- Multi-channel patrol detection control circuit c
- Flashing wall light control circuit
- Photocell trigger control circuit
- PLC light source robot hand bubble control circuit
- Digital current loop control circuit
- Relay control circuit a
- Small power electric heater temperature detection control circuit
- Forward and reverse control circuit of micro DC motor a
- Micro DC motor steady speed control circuit a
