Humidity control circuit using NAND gate and transistor
Source: InternetPublisher:走马观花 Keywords: Control circuit transistor NAND gate BSP Updated: 2020/01/03
An RC self-excited multivibrator is composed of two NAND gates
Di, Dz, resistor Rz, capacitor Cl, etc., with an oscillation frequency of
2.5Hz and an oscillation amplitude of 4V. Humidity resistor RS is used as the temperature detection element. The control circuit is composed of transistors VTi~VT4
When the humidity drops to the set value (can be adjusted by the potentiometer RPi), the relay KA2 is released and the power supply of the dryer is cut off;
at the same time, KAi is closed and the power supply of the humidifier is turned on. When the humidity rises, the RS resistance decreases, and when the humidity reaches the set value.
KA2 closes and repeats the above process to keep the indoor humidity near the set value.
- How to use a microcontroller to control a servo motor?
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Build a glove-controlled robotic arm
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Introduction to the internal structure of the Delta winding motor
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Design and analysis of the principle of automatic power-off switch during power outage
- Light-controlled circuit design and analysis
- Audio interface protection circuit
- Simple disconnection burglar alarm
- Ultrasonic blind pathfinder circuit
- Electronic anti-asthma circuit
- Crop anti-frost circuit
- Agricultural small tractor lighting circuit
- Greenhouse temperature control circuit
- Mixer built with analog multipliers
- Frequency modulator composed of NE566
- Amplitude modulation circuit composed of MC1496
- Capacitive feedback oscillator circuit
- Sawtooth wave generator circuit (1)
