Thermostat control circuit using 555 time base integrated circuit 4
Source: InternetPublisher:常思一二 Keywords: Integrated circuit time base integration thermostatic control circuit Updated: 2020/03/10
It uses a negative temperature coefficient thermistor R. (MF12 type 3kfl) is used as the temperature sensing element. This
circuit can maintain the temperature in the thermostat within a certain range (such as ZO - adjustable within 100°C). It is actually a temperature range
controller circuit.
In the figure, RPi is the upper temperature limit setting potentiometer, and RPz is the lower temperature limit setting potentiometer.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to choose the right level of integration to meet motor design requirements?
- Build a glove-controlled robotic arm
- How to build a simple tachometer using an infrared reflectance sensor
- A simple door handle touch alarm circuit
- An automated model railroad layout project using a microcontroller
- DC motor drive circuit composed of L293D
- One-way rotation circuit of motor controlled by contactor
- IGBT modules block overcurrent by controlling the gate
- Delay switch made with LM431
- Simple timing control circuit
- Electromagnet control circuit
- Three-phase stepper motor control circuit
- Photoelectric output control circuit
- Bedside touch light detection control circuit
- Automatic door detection control circuit
- Humidity detection box control circuit in greenhouse
- One of the thermostatic control circuits using operational amplifiers c
- Electric contact mercury thermometer constant temperature control circuit 3b
- Electric contact mercury thermometer constant temperature control circuit 2
